I recently dropped the l/u to replace the water pump impeller. I left the shifter in neutral, apparently not knowing any better. As with others who have tackled this, the l/u wouldn't go back easy. After reading several posts(and doing the job solo), I pulled the spark plugs to aid in turning the flywheel, put the shifter in reverse, and the l/u went right up while turning the flywheel. Put everything back together to check the water pump and it worked fine. However, no matter if the shifter is in forward, neutral, or reverse, the prop is turning clockwise all the time. I'm figuring that I did something wrong with moving the shifter control. I have went back and dropped the l/u again. How do I reinstall this time so that everything goes back like it was before I started?
