I have a '97 Astro with a 115 Merc. When decelerating it makes a loud horrible knocking and it sounds as if it is going to blow up. It does it only when decelerating, and when my carbs where gummed, it would do it every time I had a lull in speed. Compression is great and it does not do it when decelerating in neutral so i think it may be lower unit related. I've seen some people comment on the use of SS props making a similar knocking sound but I have an aluminum prop, granted it is a little beat up. Could it be another problem? it is a 19 pitch, maybe getting a new prop with higher pitch, and new hub will help?
