I bought a 1961 merc 400 the guy said he thought the water pump was bad but not sure. so i took it out on the water to see if it was peeing at all. well it peed fine while it idled in neutral the when i put it in forward it peed for a couple of minutes and quit when i gave it about 1/3 to 1/2 throttle. i shut down for a while then started so i could get back to shore but first i checked water and it was peeing in neutral again. Could i have a bad impeller or could it just be clogged? the first time i let it idle for about 5mins.
