dbarnes1952
- May 8, 2006
- 1
I am trying to identify the correct part number for my tilt & trim pump assembly. The motor has quit working and the parts are no longer available. I have found 2 used ones but don't know for sure what I need. It is for a 1981 Mercury 90hp (serial #5594863). The numbers on the pump appear to be 76395A? That's all I can make out. I have found a pump #76395A5 and 76395A2. Mine has 3 wires and 4 hoses. Also the pump says to use 10W-30 motor oil, but I have seen suggestions on using Dextron transmission fluid. Which is better to use?<br />Thanks, Don
