  #1
Old September 10th, 2003, 10:56 AM
SJ Striper SJ Striper is offline
Default Head Gasket Replacement 130 HP Yamaha
I will be attempting to change the head gasket on the #2-#4 cylinder head on my 1990 130 HP Yamaha. I have a torque wrench, gasket removal spray, and a manual that shows the bolt pattern and the torque settings. Any advice from the group before I take on this task? I will be attempting to "crack" the bolts tonight, and finish the entire job by Friday pm. Please let me know what to look out for. Thanks in advance. SJ.
  #2
Old September 10th, 2003, 01:33 PM
jim dozier jim dozier is offline
Default Re: Head Gasket Replacement 130 HP Yamaha
It should be straigt forward unless you break a bolt off. That can be dealt with. Go for it.
  #3
Old September 10th, 2003, 01:42 PM
mrn714 mrn714 is offline
Only other suggestion is to spray the bolts down with liquid wrench, let stand for some time. Your torque wrench should have on and off lbs. shown. Be sure not to exceed 10 - 15% of on for off. If you do, you will turn off the bolt. If they do not move, tapping (and I mean TAPPING) with a small hammer (plastic preferred) may give the bolts a jolt to come out. If they do, clean and soak in Liquid wrench, then use a good thread sealer when installing for the next time. If you did not learn anything today, you should have stayed in bed.
  #4
Old September 25th, 2003, 11:02 AM
FOLLOW UP .... Head bolts came right out, spent 1.5 hours cleaning old gasket off, replaced gasket, torqued to 22 pounds. Ran motor for 20 mins, ran great, pulled plugs. #2 plug had rusted look, dumped a bit of 2 cycle oil in cylinder, replaced plug, ran motor for 1/2 hour, ran great, pulled plug, looks great. Rust could have been residual from within cylinder? Have run motor 3 hours since and is running great. Thanks for the help. SJ.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1975 6 hp head gasket replacement -dry gasket? BF Johnson & Evinrude Outboards 11 July 3rd, 2007 01:46 PM
Head Gasket Replacement????? schonn Johnson & Evinrude Outboards 8 May 8th, 2006 12:26 AM
head gasket replacement- what comes off? davidkockler Johnson & Evinrude Outboards 1 June 8th, 2005 02:10 PM
Head Gasket Replacement as PM John from Madison CT Yamaha & Suzuki Outboards 3 December 10th, 2004 11:36 AM
Head Gasket Replacement Namron Force & Chrysler Outboards 3 May 17th, 2004 05:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
