I bought a used 70 HP Yamaha 2 cycle oil injected outboard. It doesn't seem to be using much oil from the oil injection tank mounted under the engine cover.
I've used about (4-5) six gallon tanks of gas and the level in the oil tank dropped to only about 75% full. After little oil useage with the first six gallon gas tank, I started adding a 50:1 mix to the gas tanks.
Anyone have an idea of how much oil the engine mounted oil tank holds and what I should expect for oil usage?
Thanks
