  #1
Old September 3rd, 2003, 04:23 PM
quonset quonset is offline
Default Yamaha 150 fuel injection
My 2000 Yamaha 150 High Pressure direct injection engine was not started for 2 years. I drained the fuel from the fuel distributor housing and the filter. I pumped it up with clean fuel but it will only run while feeding it starting fluid.What is wrong?
  #2
Old September 3rd, 2003, 08:46 PM
Skinsk Skinsk is offline
Default Re: Yamaha 150 fuel injection
Probably clogged injectors.. Those motors don't like to sit. And be carefull with that starting fluid. It may be a clean running motor, but it's still a 2 stroke. Starting fluid has no oil mixed in with it.
  #3
Old September 7th, 2003, 07:07 PM
rodbolt rodbolt is offline
hello test the High Pressure fuel pump pressure. these little pumps like to stick. you should hear it run for 5 seconds when you turn the key on . if you dont test the pump for correct voltage.if all else fails you can use 12 volt jumper leads on the pump terminals. this little pump aint cheap so test it well before replaceing. good luckthe pump is marke pos and neg at the terminals
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Oil injection (?) khoi30 Yamaha & Suzuki Outboards 1 November 9th, 2006 12:10 AM
50 HP Yamaha Oil Injection= fuel starvation Glyn Ryan Yamaha & Suzuki Outboards 1 March 14th, 2005 03:01 PM
yamaha fuel injection backdraft Non-Repair Outboard Discussions 5 July 29th, 2004 09:25 PM
yamaha oil injection igofishn Yamaha & Suzuki Outboards 2 June 12th, 2003 07:44 PM
yamaha 115 1990 oil/fuel injection! snookit Yamaha & Suzuki Outboards 2 October 27th, 2001 01:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
