Re: 1980- 81 9.8 HP Merc 110 Tough to start then easy
Laddies, Thank You again for your response. Sure, as I pulled the choke knob out I figured the choke was closed. I foolishly disregarded your mention of a two peice choke butterfly as mine has only peice. So this morning tried to start it again and had the same problem(hard starting). I pulled the cover off and checked the butterfly. Although the choke knob was all the way out the butterfly was not closed all the way. I held on to the knob in order to pull it out( past where it clicked) and close the butterfly all the way.Started up easily. With your advise I believe the problem to be solved.Saved me from wasting time and money on an unnecessary repair. Once again Thanks to you and all of the other posters on this site. I could not own a boat without it. Love your life and enjoy your day.
