Re: spinning prop
It doesn't have to be completely out of the water for the rpms to sky-rocket... You may just be loosing prop bite on the water.. Try to turn with the motor trimmed down and see if it happens again. If it doesn't the motor is trimmed too high or too high on the transum. If it still does, it could be a spun hub. You can make marks with a permanent market on the inner and outer hub so they line up with each other. After a run on the lake, if they don't line up again, the hub is bad...
