Re: 1969 Mercury 100 H.P. Thunder bolt lower unit
Common mistake. The shift shaft is free to rotate quite a bit when the lower unit is in Fwd gear.<br /><br />The correct position for the shift shaft (if you plan on installing it with the remote control box in Fwd), is rotated counter-clockwise until it stops (while still remaining in Fwd gear). When you are at the correct position, any further rotation of the shift shaft in the CCW direction will shift the gears to Neutral.<br /><br />Some folks prefer to place the gearbox in Neutral when reinstalling, because there is a positive detent which Fwd gear lacks. However, you must ensure that the remote control box is also in Neutral.<br /><br />As you're installing the lower unit, you'll have to rotate the flywheel a bit in the clockwise direction to get the drivshaft to engage into the crankshaft splines. At around the same time the shift shaft is engaging the shift rod, so lots of fun there!<br /><br />I prefer installing with the L/U in Fwd gear, since moving the prop slightly in the Reverse direction will cause the driveshaft to turn, thus engaging the crank splines easily. <br /><br />Reverse rotation will have no adverse effect on a new impeller but you'd never want to rotate your motor in the wrong direction with a used impeller, as it could cause the impeller vanes to break.<br /><br />If you reinstall in Neutral it's good to have a 2nd person or long arms to turn that flywheel!!!
<br /><br />You may find the shift shaft a bit hard to reposition with your fingers; if you're very careful, you can use a pair of Channelocks or similar, providing you cushion the jaws with duct tape etc to keep from tearing up the splines of the shift shaft. Grab the shift shaft and rotate CCW. It does help to spin the prop with your hand while manually shifting to the desired gear.<br /><br />BTW you definitely want to replace the impeller while you're in there; cheap insurance. I get great prices and fast shipping on parts at this site:
www.boatfix.com<br /><br />Here's a search for genuine Merc replacement pump parts:<br /><br />
http://www.boatfix.com/bykeywordmerc.asp?textfield=47-89984&texttype=2&submit=Search <br /><br />And Sierra aftermarket ( 18-3017 for the impeller, 18-3517 for the entire upper pump kit including impeller):<br /><br />
http://www.boatfix.com/searchsierra.asp <br /><br />HTH & G'luck............ed
