I have a 1998 Mercury 60HP 2 stroke 3 cylinder. It has been rebuilt by me and its my first time. I have replaced the stator in the same position that it came off and the trigger coil seems to only go one way. The fly wheel can only go on one way as well. The manual says timing at idle should be between 2o ATDC to 6o BTDC. If I set the timing to that the engine will not start. If I set the timing to 10o BTDC the engine starts. What should I do? Is it time to pay a shop to time it?. Any clues where I went wrong?<br /><br />Thanks
