fishingdave
- Sep 15, 2004
- 55
How hard are the popet valves to change on a 1999, 150hp blue water series?? The reason why i am changing them is because, the motor seems to run hot durring idle and the water out of the tell tail is not that force full & hot. I replaced the water pump and tstats. I noticed durring idle that there is water coming from where the two anodes on the lower unit are, looking at my good old manual that is where the popet valves dumps off at. I am not sure if that is normal durring idle is it?? Also when i did a search about my problem lots of people said that if it was wide open the motor would over heat, but how come my manual says that the motor will run cool and never make it to operation temperature?? Is it because of year?? <br />Well i just want to make sure that the valve is the problem before I messing with something where i can brake a bolt!! I know what salt water does to motors. any help would be great!!
