Re: 1971 merc 7.5 impeller repair
Remove 2 nuts one in the front of the unit, it's 5/16 NF and faces up, one under the cavition plate 3/8 NF facing down. drop the unit down and the pump cover is held on with 2, 1/4 NF nuts remove the cover, lift the s?steel plate out, turn the impeller to loosen the key and impeller on the shaft, lift or pry the impeller out of the hsg. carefully. Grease the shaft and key to hold in place in install the impeller. Ypou may need to turn the shaft and impeller to get it in the hsg.<br /><br />The best advice I can give you is to buy a MANUAL
