Need help please. Took the boat out recently and had some issues. Was out for a few hours no problems and then on the way home I got up on a plane and the Engine just shut off dead. Started it back up gotr up on a plane and same thing. Next time starting was difficult. Had to push handle almost all the way forward to start. When I would back it off to Neutral it seems to idle fine. When I put it in gear it would die almost immediately. Went through this for about 20 minutes until finally it got harder and harder to start. Finally would not start at all. Got towed!!<br /> Took it in for service and everything checked out good. Compression was real good. Said the timing was off, but that was my fault. When it would not stay started in gear, I messed with the idle. He changed the plugs and said it water tested fine. So I took it out the next day. Ran fine at idle in neutral. Put it in gear and it felt very shaky and felt like it was going to die any second, which it did. Before I take it back in I wanted to get some opinions from the knowledgable people here.
<br /> Any help would be greatly appreciated.
<br /><br />The only other thing is that I ran pretty hard aground recently in the keys. Would not pee for a few minutes but eventually cleared and never overheated.
