Saskatoon2005
Master Chief Petty Officer
- Apr 27, 2005
- 810
Hello all, I had enough trouble with this motor last year that I decided to let you guys help me out right from the start. I have a 1973 Mercury 7.5 Hp Outboard motor. I would love to get it going because my 40 Hp Johnson guzzles the gas, and at $1.14 per litre here in Canada at the moment, I would still like to get out and fish.<br /> <br /> So where to begin...I tried starting the motor last summer and after pulling my arm off it started and ran beautifully. I let it run for like ten minutes and turned it off. I tried starting it again twenty minutes later and nothing. Pulled and pulled and pulled and nothing. After a really great local mercury dealer told me to replace the stator coils, I did. I pulled and pulled for a while more before deciding that the stator coils were not the problem. I removed the carbeuretor and cleaned it right out. Checked the points and they are in great shape. This motor ran beautifully the last time it was used and now I can't get it going. Does anyone have any insight as to what I should be trying to do? I tested the ignition module and it is great. I tested the capacitor and it is great. I checked the stator coils and they are great. Is there anything I could be missing? I check and found that the carbeuretor gets gas. Spraying into the carb does nothing for starting it. I am sure it is electrical. What should I try to get this beast moving.....LOL! Please help fishing season is here soon and I don't want to miss it again. Serial number 7009691. It is a Canadian model.
