  #1
Old July 23rd, 2003, 09:05 AM
DENNISP3 DENNISP3 is offline
Default Yamaha over heating problem
I have a 1987 Yamaha 150 outboard that is over heating when you run above 4800 RPM. I change the water pump and I now believe the problem is a build up of salt deposits in the heads! In lue of removing the heads and buying new gaskets etc which will cost $170.00, I have another idea to possibly correct the problem. If I remove the thermastats and pour some salt eating solution in the heads to eat out the salt this may correct the over heating by increasing water flow. My question is has anyone tried this and what type of solution will be effective. thank you
  #2
Old July 23rd, 2003, 09:35 AM
moderator1 moderator1 is offline
Default Re: Yamaha over heating problem
Moving to Yamaha questions.
  #3
Old July 23rd, 2003, 10:18 AM
jim dozier jim dozier is offline
I had a similar problem with my Suzuki. I removed my heads and after manually scraping the aluminum and salt deposits out of the head it is my belief that if they are clogged to a degree that it is affecting flow, manual cleaning is necessary. This stuff is tough. It is mainly aluminum carbonates and aluminum hydroxides which are byproducts of the corrosion of aluminum. There may be some salt mixed in, but salt is not your problem because salt is soluble in water. The aluminum compounds are not. The use of something stronger like acid is not a good idea because the aluminum metal is also soluble in acid. The acid will eat away at the joints and cracks which have more surface area and do damage where you don't want it and probably not do much to the clogs. I put some acid in a test area of the cooling channels of my head when it was off and the deposits do not dissolve easily.There are products on the market like Salt Away and I have no experience with them, but I know the chemistry and it is my guess that if they have some utility it is in the area of prevention and not cure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 130 over heating MichaeltMoir Yamaha & Suzuki Outboards 4 April 17th, 2007 09:27 PM
351 over heating problem formula351 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 2nd, 2006 06:54 PM
1999 4-stroke 50 hp yamaha over-heating David R Lewis Yamaha & Suzuki Outboards 0 March 22nd, 2006 05:19 AM
YAMAHA OVER HEATING PROBLEM DENNISP3 Johnson & Evinrude Outboards 1 July 23rd, 2003 09:35 AM
Re yamaha 60 over heating emmerson2 Yamaha & Suzuki Outboards 1 January 25th, 2003 07:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
