Hi All.<br /><br />Looking for any suggestions regarding a wiring problem I have on my Mariner Magnum 200hp EFI (Ser# 0G076889)<br /><br />Initially, my stator went so got that replaced. Got the engine running, but only with the kill wires disconnected on the power packs, and with the low oil alarm going. I thought this was an ignition switch problem so replaced that to no avail. Next idea was to disconnect the alarm from the ignition (I know not the best option), the engine then ran fine (for about 30min) until the fuel pump stopped. Again, bought another fuel pump - this was not the problem - since then I have had the ECU tested but that has come out fine. <br /><br />Does anyone have any idea's as to where the fault could lie ? I know the best option is to send it in but I live in Tanzania so there are no competent dealers here. Short of flying up a mechanic from South Africa, I am at a loss.<br /><br />I recall seeing that the engine cuts after 30min-45min once the oil alarm sounds. Could this be the case ?<br /><br />Thanks.<br />Stuart
