I bought a 1995 Procraft about 2 weeks ago from an private owner. I took it out the first night I had it, and it started fine (just like it did on the muffs) idled smooth the whole nine yards. I take it out into some open water and open it up and it takes off no problem. After it planed out and started to build up speed it just died, basically like I turned off the power to the motor. I repeated this several times before I decided that there was something wrong and brought it back in. <br /><br /> After I got it loaded back up on the trailer I noticed some fuel near the bulb, I inspected and it had a crack in it. I replaced this and the spark plugs (the old plugs looked really bad) and took it back out on the lake again. Same thing, only this time after about 10 min it would not rev above 2500 rpm with the prop engaged. At this point I putted back in and decided to take it to a local marine shop.<br /><br /> After sitting at the shop a week they guy calls me today and tells me that my #2 and #6 Cylinder have zero compression and that I need a new motor. <br /><br /> Please help a new guy out, this makes no sense to me since the motor was running, and will rev up with no problem with the prop disengaged. I dont know enough about outboards to make a decision on my own so Im hoping some of you gurus can help me.
