Hey gang, <br />Nice forum,<br /><br />I have an XR150 Mercury outboard and have replaced the impeller a long time ago. the PSI on the guage is not up to par and have decided to replace it again. <br />I removed the trim tab, removed the other 4 bolts but can not get the lower unit to separate. then I remembered that this might have a shaft that has to be removed under the carbs. There is an "L shaped arms to the shifter control but really don't see how to remove it. <br /><br />any suggestions...<br /><br />thanks in advance.<br />Smilin' Jack
