ROBERTSTELLJR
- Apr 10, 2006
- 10
HI, I JUST BOUGHT A MARADA 18' BOWRIDER AND CANT FIND A WEBSITE FOR THIS BOAT...PERIOD. TRYING TO LEARN ABOUT THE TRANSOME, WHEATHER OR NOT IT HAS A COMPOSITE TRANSOME OR GLASS WHERE THE OB BOLTS UP. THE FOOL THAT HAD THIS BOAT BEFORE ME USED SQUARE WASHERS INSTEAD OF THE ROUND WASHERS AND PULLED IN AND CRACKED SOME OF THE MATERIAL ( WHICH I THINK IS GLASS ) AND IM NEEDING TO REPAIR. IT WILL PROBABLY BE FINE BUT I DONT LIKE IT AND NEED TO DO SOMETHING. DOES ANYONE KNOW IF THERE IS A REPAIR KIT AVAILABLE OR IF I SHOULD JUST FILL IN THE SPOT WITH SOME TYPE OF RESIN AND POSSIBLY PUT AN ALUMINUM BACKING WHERE THE MOTOR BOLTS UP ON THE TRANSOME...ITS JUST THE UPPER LEFT BOLT HOLE IF LOOKING AT IT FROM THE BACK BOAT.IF YOU HAVE ANY IDEAS AS TO WHAT I SHOULD DO PLEASE SEND A REPLY, AND I HAVE LOOKED ALL OVER FOR A WEBSITE TRYING TO FIND ANY INFO ON THE MARADA BOAT LINE, IF YOU HAVE ANY HELP THERE IT WOULD BE GREATLY APPRECIATED...THANKS ALOT, ROB
