I have a 1995 (or 1996) Mercury 115 Tracker outboard. I have searched the board for this answer and I did not see it. My trim on land and at idle will trim up and down with no problem. However, while under way the motor will not trim up. (It tries but the motor just starts bouncing)If I stop and trim and then go, it SEEMS to stay trimmed up. I am in the process of doing a overnight test.<br /><br /> I checked the fluid and when I unscrewed the big flat head screw at the bottom of the pump it had oil. Just in case I put more in until it was pouring out. I am in the dark here. I am thinking either 1)need to bleed the cylinder 2)I am adding fluid wrong or 3) my trim motor has seen better days and I about to shell out some serious clams.<br /><br /> It seems that 90% of the trim problems on here are electrical, which is understandable given electricity is a pain. However, mine seems to be a trim problem while under load. I think my motor is just weak on its way out but I am praying it is a solenoid <br /><br />Thanks in advance for any help.<br /><br />Brad
