Plainsman
- Apr 2, 2006
- 4,062
Hello, <br /><br />I have a 1976 115 HP Mercury, serial # 4313752. I'm not sure if "trim Pump" is correct, but when I push the In/Out In, it hums.<br />My question is, how do I check the oil level in it? I see a sticker that says to use 20W oil. I see a large screw that takes a ratchet extention and in there is a straight slot screw and above that is an allen screw. The trim does not move in or out, but the pump seems to work.<br />Also, on the side is a large knob that says something about a reverse lock and not to operate the boat with it disengaged. <br />This is my first boat, so please bear with my if I ask seemingly simple questions.<br /><br />Eric
