EHardgrave
- Mar 25, 2005
- 56
I took my 7.5 merc. (s/n 5343319) out for the first time after an impeller change. When I started it I noticed no water coming out. (it did work in a garbage can right after new impeller) I dropped the lower unit to see what happened to the water pump and in on top of the pump, shaft, etc. was a milky oily water mixture. From reading other entries I would assume an oil seal somewhere. Does this sound accurate? If so then I am confused about what kit I need. Does kit # 18-2628 have everything I would need or do I also need the water pump seals # 18-0516 and maybe 18-2010? Or is there possibly something more wrong? What PSI would I use to pressure check? Thanks
