When you say fitting, do you mean a quick connect device that is somehow perminently screwed in the screwhole labled "FLUSH"?
I as because on some motors that can be above the waterpump and cause a problem if done while running.
Whereas the earmuff type connection should provide a good suppy to the water pump when properly placed over the intake screen.
