  #1
Old June 15th, 2003, 02:27 PM
dpdowling dpdowling is offline
Default 115 yamaha outboard main bearing trouble?
I have a 115 yamaha v4 that was nebuilt just last year. it has about 100 hours on it. I run a 50/1 mix of oil to gas in my main tank on top of it being fuel injected as I also use the kicker motor run on the same tank an to give added lube to the engine. I was cruising at about 2500 rpm when I heard the motor suddenly start knocking. I shut it down and limped back in on the kicker. the motor starts and runs but knocks and the fly wheel lifts about 3/8" when it cranks over. I can also lift the fly wheel the same by hand. I think this could be a top main bearing. My question is do I have to pull the whole powerhead and seperate the head and crankcase to get at the bearing or is there a way I can remove the fly wheel, stator, and remove and replace the bearing. would a bad bearing allow the flywheel to lift? would it also cause any damage interally? Thanks,dpdowling
  #2
Old June 15th, 2003, 07:24 PM
Capt Ken Capt Ken is offline
Ensign
Default Re: 115 yamaha outboard main bearing trouble?
Not the upper bearing that holds the crank down. It's the lower bearing that is fixed on the crankshaft and holds it in place via a retaining clip. If the flywheel don't move from side to side, the upper bearing is probably OK. The knock is something else and you're probably looking at a teardown.
  #3
Old June 18th, 2003, 06:44 PM
coolblue1152 coolblue1152 is offline
You know what you have to do!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Main Bearing Dowels perkdp Johnson & Evinrude Outboards 5 March 29th, 2006 08:23 AM
oil to the center main bearing tvpear12 Johnson & Evinrude Outboards 3 August 29th, 2004 06:35 AM
Top main bearing clearance? vissertrades Johnson & Evinrude Outboards 4 December 11th, 2003 02:02 AM
'94 johnson 90, bad lower main bearing snohomishbaddawg Johnson & Evinrude Outboards 3 August 1st, 2003 04:51 PM
Bad fly wheel main bearing.... sabrajf Mercury & Mariner Outboards 0 March 9th, 2003 12:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
