Re: bow pulpit
- Build it strong enough to carry at least 4X the working load of the anchor line. You don't want it to crack just when you need it the most.<br /><br />- Make sure it's VERY well supported. You may need to add backing plates or blocks inside the hull. Use a good polyurethane sealant. <br /><br />- Build the pulpit with an integral bow roller. Makes the line much easier to deploy/retrieve.<br /><br />- If you plan to stow your anchor in the pulpit, make sure it fits properly in the opening and that there's a cleat very close for securing. A protection plate below the pulpit will keep the boat's nose free of gouges.
