  #1
Old June 2nd, 2003, 07:27 AM
Saltymut Saltymut is offline
Default Fuel/Oil Mixture Conversion '85 Yamaha 220
I'm interested in anyones input on converting my '85 Yamaha 220 O/B to 50:1 mixture rather than using the remote oil tank with oil pump. The reason for the conversion is that the oil pump is on it's way out and a new one is going to run me about $300....OUCH !!! Here's what info I'm hoping to gain from you guys:Can it be done on my engine?I read somewhere (unreliable source) that it's bad for the carbs to mix.What is the process of the conversion?How hard is it to do it myself? (I'm fairly mechanically inclined)What are the advantages/disadvantages to mixture rather than the remote tank?Thanks,Saltymut
  #2
Old June 5th, 2003, 12:54 PM
Default Re: Fuel/Oil Mixture Conversion '85 Yamaha 220
Bumping up !!!
  #3
Old June 6th, 2003, 05:48 AM
One last time !!! Bump
  #4
Old March 20th, 2005, 03:31 PM
Parkhil2 Parkhil2 is offline
Has anyone successfully performed this conversion? Is it bad for the carbs?
  #5
Old March 21st, 2005, 02:40 AM
rodbolt rodbolt is offline
hello happens all the time. its a rather expensive pumpkit. if you wish to eliminate it. remove the oil tank and control module. remove the pump, remove the pump drive shaft and reinstall the pump. remove the pump link arm. remove the remote tank and mix fuel at 50/1.
  #6
Old March 21st, 2005, 03:15 AM
Ray Neudecker Ray Neudecker is offline
I prefer to remove the oil pump and replace with the cover plate for the consumer version V-6 and cap off the oil lines at the intake. You will need to pay more attention to draining the carbs before putting up to prevent the carbs from clogging over a long period of setting the engine up.
  #7
Old April 27th, 2009, 11:00 PM
RICOSUAVE7777 RICOSUAVE7777 is offline
I Have The Same Problem With My 88 200 Yamaha.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 9.9: Where is the Idle Fuel Mixture screw? (pic) ST Yamaha & Suzuki Outboards 5 April 16th, 2006 03:02 PM
Yamaha 40 hp to 50 hp conversion sparkes Yamaha & Suzuki Outboards 3 August 16th, 2005 08:48 AM
How many turns for air fuel mixture 91 yamaha 115 MAKO72 Yamaha & Suzuki Outboards 1 November 4th, 2004 09:32 AM
Yamaha 28a Fuel Mixture tcob1 Yamaha & Suzuki Outboards 0 August 4th, 2003 03:25 PM
28 HP Yamaha...mid '70's...fuel mixture... Tick Yamaha & Suzuki Outboards 5 January 6th, 2003 10:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
