Re: Raising Motor
Great idea Formula1974. Using the trailer jack works great. It is a one person job.I suggest the following modification to original approach. Leave the bottom bolts in but loose, remove the top two bolts. Before removing bolts cut a 29" (approx) piece of 2" X 10" cut to fit around the motors bracket right at transom and wedged between bracket and ground. Raise front of trailer, back of boat goes down, motor stays put. Replace bolts and tighten. Thanks Formula1974.<br />Tom Quinn<br />PS- I also used 2 wedges of wood between bracket and transom top, just for stability- probably not needed.
