painting the bottom of a center console
drfish18
what is the best and most reasonable method of painting a center console? What I mean is cost and type of paint.
crazy charlie
Re: painting the bottom of a center console
Bottom paint starts at about $69 a gallon.Anything that has at least 40%copper will be ok for Jersey.West marine has their own brand in that range.Wait until spring and roll it on.Charlie
bayman
Make sure you get the right paint for the type of material and pay close attention to the manufacturers instructions - otherwise it might not stay on long.
Solittle
Do you do most of your boating in salt water? if so how long do you keep it in the water? If you do only day outings you may not need to paint it.
drfish18
Originally posted by SoLittle:<br /> Do you do most of your boating in salt water? if so how long do you keep it in the water? If you do only day outings you may not need to paint it.
drfish18
I keep my boat in the salt water for six months.
crazy charlie
Originally posted by crazy charlie:<br /> Bottom paint starts at about $69 a gallon.Anything that has at least 40%copper will be ok for Jersey.West marine has their own brand in that range.Wait until spring and roll it on.Charlie
6mos. in salt...I quote myself !!! Is that a first??? :confused:
Dead Eye
You get what you pay for. I uas multi season paint. Boat is in the water 8 months. Power wash at the end of the season and thouh up in the spring. Good Multi- season paint will last at least 2 years. I get 3 only have to touch up chips and the water line.<br /> Dead Eye
Perfidiajoe
I don't believe anyone has mentioned it, but it is also inportant to know if the fresh paint will work over the paint that is already there. You might have to remove the old stuff, some paint will go over anything some won't. Since I haul the boat every year, I paint every year, not worth the haul out mid season if multi year paint fails mid year 2. I use the West Marine $69. paint, & apply it with a 6" brush after a light scuffing. Been doing this for years here on Long Island, NY with no problems. Good Luck, Joe
