  #1
Old May 27th, 2003, 08:45 PM
Noodler Noodler is offline
Default 115 Yamaha Idle/Acceleration Problem
1989 Yamaha 115 HP/ model 115ETLF Hard start, poor idle, dies upon acceleration. Then runs like a top above 1500 rpm to WOT. Ran fine last summer,was winterized, has fresh fuel,always have used fuel stabilizer, fresh NGK B8HS-10 Plugs,fresh oil,Plugs are not wetHave good spark at all plugs, will rev up fine when not in gear,however, under load hesitates or stalls, not smoking any more than normal, what do I need to check for this problem? Thanks
  #2
Old May 27th, 2003, 08:48 PM
tscott tscott is offline
Default Re: 115 Yamaha Idle/Acceleration Problem
I had a similar problem with my '91 evinrude 200. Turned out to be a plugged fuel filter. Might start there and one of the more knowledgeable people will probably be along shortly to help you further.
  #3
Old May 28th, 2003, 04:17 AM
maryhislop maryhislop is offline
I am having the very same problem with my Yahama 70. We did clean out the fuel filter. It was plugged with sticky rubber from an old fuel line. Now that it is clean, what else should I try? Should I take the carborator off and clean it? At times, it runs perfectly. We have replaced the hose also. Are there any lines in the motor that would need cleaning?
  #4
Old May 30th, 2003, 08:47 PM
Thanks, I have replaced the fuel filter,checked the lines,Primer bulb is ok,any other tips?what is involved in cleaning the carbs? Is this the same as a rebuild?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 225, rough idle, hesitates on acceleration jeuto Yamaha & Suzuki Outboards 6 May 31st, 2006 09:54 PM
2000 Yamaha F100 Start/Acceleration problem. diveextreme Yamaha & Suzuki Outboards 4 July 27th, 2004 01:08 PM
Yamaha 200 weird Idle problem on/off Yamaha & Suzuki Outboards 2 August 1st, 2003 12:01 PM
Yamaha 115 four stroke idle problem ReelSlick Yamaha & Suzuki Outboards 0 July 10th, 2003 11:49 AM
YAMAHA 40 IDLE PROBLEM THE SKIPPER Yamaha & Suzuki Outboards 0 June 16th, 2003 07:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
