2000 25hp bent & twisted prop shaft
dgood64967
I bought a 2nd hand 25hp 2stroke with a wobble on the prop when it ran, any advice on a bent prop shaft w/abit of twist to the spline, the thrust hub will not come off over the twist, should I sawzall it off, or...<br />thanks<br />Doug
Laddies
Banned
Re: 2000 25hp bent & twisted prop shaft
If you can't get it with a puller then you will probably have to cut it
