Re: 70 hp merc rebuild
Once you open it up, you need to examine the condition of the cylinder wall to evaluate the extent of the damage. That cylinder cannot be re-sleeved, but it can be machined up to .030" oversize if necessary. If the scoring is light, you may be able to simply hone it. Aluminum deposits on the bore can/must be removed with muriatic acid before honing. While you have it apart, it is a good time to replace the crankshaft seals and inspect the bearings, reeds, carbs, etc.<br /><br />Most important, you should be confident that you know the reason the piston burnt up in the first place, to make sure you don't do it again and fix any of the reason(s) why it did.<br /><br />Have a peek at the links in my sig for info about my 60hp rebuild process.<br /><br />Good luck.
