I have a 1975 Mercury 650 O/B. It is on a 1975 14.5' Sportcraft Runabout (no poer trim or tilt). I just replaced (what i think was) the original prop. I replaced the prop because the hub was "slipping". I could idle out fine, but when i hit the gas, the boat moved just as slowly, but the engine was full throttle. When I pulled the old prop, the old thrust washer (nearest the gearbox) was "very shiny" and the serial numbers on the prop were rubbed off. The mechanic at the marine shop in town said that the hub went bad.<br /><br />OK, here is the new problem. I put a new prop (Comprop) on and took it out to the lake with the kids. My son was driving and I was kicking back, relaxing. All of the sudden, I saw the motor pull out from the boat about 6 inches, then drop back down. The motor was running the same speed (rpm) but it felt like the boat was not moving as fast. I thought maybe we hit something under the water, but we pulled into a cove and I pulled the motor up and looked at the prop. No dings, no scratches, no sign of contact. I pulled the prop off and noticed that the gearbox end of the prop was scratched (inside and outside). If you don't know about Comprops, they are composite props that look as if they are plastic, but are as strong and durable as aluminum. It appeared to be rubbing against the gearbox housing. The thrust washer moves with the prop.<br /><br />Here's something else. When I installed the new prop the lock washer fit snug against the propeller and I screwed the lock nut on tight. When I pulled the motor up today, there was a 1/2" gap between the lock washer and the front of the prop hub. The lock nut does not fit past the threads (does not fit over the splines), so it is not like the nut backed out or anything. The lock nut is tight to the end of the thread on the prop shaft. The prop itself slides up and down the shaft that 1/2". Is this normal? <br /><br />1) Should I get another thrust washer, since the old one is obviously worn? <br />2) Should the prop have play in it on the shaft? <br />3) Should there be wear on the gearbox side of the prop? <br />4) Is there supposed to be anything between the prop and the gearbox housing? (grease, seal, bearing, etc)<br /><br />Please reply if you can answer any of these questions. I don't want to ruin this "fixer-upper"
