  #1
Old May 10th, 2003, 03:14 PM
martevans martevans is offline
Default 1991 Yamaha 200 warning buzzer
Warning buzzer goes off when turning ignition switch to on position. It does not stop upon starting motor. Great water flow, oil tanks full and pumping. Did the 91's have a voltage sensor which could alarm like this? Could it just be a loose battery connection? It seems that the motor is also RPM- limited.
  #2
Old July 24th, 2004, 08:32 AM
jvernon jvernon is offline
Default Re: 1991 Yamaha 200 warning buzzer
I have a similar problem. Yamaha C60TL. New battery. I have checked wiring and connections. Does not seem to be overheating. How was this problem resolved?
  #3
Old July 24th, 2004, 11:31 PM
casper5280 casper5280 is offline
I also have the same problem on my 1997 130hp.This does not happen all the time just every now and then.The last couple times I've just started the motor and after a few seconds it stops and everything is fine.I've checked all the normal things and everything seems fine,but this still bugs me as I do a lot of offshore fishing.
  #4
Old July 26th, 2004, 07:38 AM
Ray Neudecker Ray Neudecker is offline
I am not aware of a voltage sensor on the 91 models. If you have low battery voltage, it is unlikely the engine will start. You can disconnect the temp sensors one at a time to eliminate a shorted temp sensor. The oil warning system should be the only other source of this problem. Check carefully the connections for it first.
  #5
Old July 26th, 2004, 05:36 PM
I think I read somewhere that the alarm on my motor '96 C60 could be either overheating or low voltage. It doesn't have oil injection so no low oil alarm. I replaced my battery (it was shot) and the motor ran quite a bit longer before the warning buzzer went off. I was going to replace the charging coil because it seem to have 0 resistance, but before I take the flywheel off I would love to have somebody confirm (or dispute) the direction I am heading.jv
  #6
Old July 26th, 2004, 07:10 PM
In jv's case, a voltage situation is highly possible. Check the voltage at the battery before starting the engine (13 volts or so). Check again with the engine running. It should increase if the charging circuit is working. If not you are going in the right direction.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Warning Buzzer -- Overheating? dharris02 Yamaha & Suzuki Outboards 9 November 4th, 2008 07:45 PM
Warning Buzzer 1988 115 Yamaha SliderM72 Yamaha & Suzuki Outboards 3 August 2nd, 2007 08:04 PM
Yamaha Warning Buzzer seamanship Non-Repair Outboard Discussions 7 September 6th, 2005 02:00 PM
Yamaha Warning Buzzer -- Overheating? dharris02 Yamaha & Suzuki Outboards 0 May 27th, 2003 12:26 PM
85 Yamaha 90 HP Warning Buzzer ? Help !? starcraft Yamaha & Suzuki Outboards 4 May 19th, 2002 05:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
