  #1
Old April 21st, 2003, 07:07 AM
harrellusa harrellusa is offline
Default 89 Yamaha 225 - Bogs Down
I just purchased a 89 Yamaha 225 to replace a 200 Mercury for my boat. The engine was installed and rigged by authorized dealer. When I open throttle to full, the engine revs up to WOT, but after only a couple of seconds, it starts bogging down to about 3500 - 4000 rpm. Dealer has checked fuel lines, pumps, plugs and thinks it might be the computer. Anyone else had any experience like this?
  #2
Old April 22nd, 2003, 05:44 AM
MIKENVAHBEACH MIKENVAHBEACH is offline
Default Re: 89 Yamaha 225 - Bogs Down
I have the same motor and the same problem, let me know whats up? would ya?
  #3
Old April 22nd, 2003, 08:00 AM
tgodiver tgodiver is offline
I had the same problem turn out to be the bad CDI unit, but it was a 98 Yamaha 225hp. I don't think CDI were put on 89 year models.
  #4
Old April 22nd, 2003, 10:43 AM
Capt Ken Capt Ken is offline
Ensign
You've got a bad fuel pump. The Yamaha V6's have dual pumps and if one goes bad, its does just what you describe. The second pump won't carry enough fuel to run the engine past 3000 rpms. If you slow down, the single pump will refill the carbs and you can run normally until the carbs run low again. Buy two kits and rebuild both.
  #5
Old April 22nd, 2003, 10:53 AM
FlyBoyMark FlyBoyMark is offline
Ensign
Make sure you have the proper size fuel line for your outboard, you might have one too small...too long or clogged. Are you running a water seperator....could be plugged up too.
  #6
Old April 24th, 2003, 07:14 PM
Anybody have any idea how much it should cost to have the carbs rebuilt?
  #7
Old April 25th, 2003, 05:03 AM
blazed4x4 blazed4x4 is offline
Ive seen a few problems on the 150- 200 yamis around that year with the same type of problem. Rebuilt the carbs two even three times. No good. Wound up replacing carb bowls cuz there was blockage under the seat(fuel inlet). Motors ran beautifully! p.s. seats are not removeable
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
8hp Yamaha bogs at high speed..HELP !! palsal Yamaha & Suzuki Outboards 0 July 8th, 2006 02:46 PM
Yamaha 50 very rough idle & bogs tal Yamaha & Suzuki Outboards 9 April 2nd, 2006 09:19 PM
86 /70hp Yamaha Bogs at wot Larry Sapp Yamaha & Suzuki Outboards 3 January 21st, 2004 03:55 PM
Yamaha F100 Bogs Down stauter99 Yamaha & Suzuki Outboards 2 February 7th, 2003 02:21 AM
30 HP Yamaha bogs down Fishyone Yamaha & Suzuki Outboards 0 July 4th, 2002 02:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
