  #1
Old April 14th, 2003, 05:36 PM
Benday Benday is offline
Default 9.9 yamaha water cooling problems
Several times my piser tube has gotten stopped up and the engine appears to be heating up, missing etc. As it is mounted way out on the stern of my sailboat and hard to get to to service, I cut her off before it gets seriously hot. When I take the cowl off and go to the tube and remove it from the pitot on the head it is wet and after clearing the tube it pumps well and the engine does not run hot or miss anymore. My question: is the piser the only place that water comes out of the engine (can't be) and 2. is it possible that the other water exhaust is clogged or blocked. As I only run the engine at a slow rpm and not a lot, but when I need it I want it there working.Thanks,Ben
  #2
Old June 15th, 2003, 08:47 AM
Feral Cat Feral Cat is offline
Default Re: 9.9 yamaha water cooling problems
If it is a 9.9 4 stroke, most of the water exits through the prop, along with the exhaust. I have two 9.9's on my boat, and they become clogged with salt. Fresh water flushing helps, and pulling the thermostats( very easily done) will give you an idea of how clogged they are. A product called SaltAway may help, have also heard that flushing with a fabric sofener is just as good and a lot cheaper.
  #3
Old June 18th, 2003, 06:40 PM
coolblue1152 coolblue1152 is offline
I don't think those little motors have overheat alarms. I you sure it's getting too hot. You need to know the temp. You can tell to some degree by touching it. If it is getting hot enough to miss you better not do that again it will distroy itself. The pisser hole on my last engine glogged offten. I would just run a small wire in it to clean it. This is only for indication of water flow. It has very little to do with cooling the engine. So find out if you are really over heating. Buy a manual. Follow the procedure for the termostat checks. I bought a engine that was 90% blocked with salt and corrosion. You need more info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
YAMAHA 4 HP 2 STROKE WATER COOLING CHECK? rajabatis Yamaha & Suzuki Outboards 0 January 4th, 2007 09:25 AM
Engine cooling water temp sensor 2000 yr carb 175 yamaha v-6 mclamown Yamaha & Suzuki Outboards 2 December 8th, 2006 08:12 PM
Rodbolt: cooling water temp sensor 2000 yr carb 175 yamaha v-6 mclamown Yamaha & Suzuki Outboards 5 December 8th, 2006 07:54 PM
1996 Yamaha C 150 cooling problems Bill Black Yamaha & Suzuki Outboards 2 August 20th, 2006 01:49 PM
Water Flow Problems on a 50 Yamaha kolortyme Yamaha & Suzuki Outboards 1 August 6th, 2005 08:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
