Re: Injection oil
Just to reiterate what AKA Lubedude is saying, because there seems to be a little confusion - the Optimax (aka DFI) oil will be excellent for your motor, no need to drain it. The issue is: this kind of oil (DFI oil) is much more expensive than "regular" TCW3 oil because it's engineered for the high-tech DFI engines. While it will work just fine for your EFI engine, it is not necessary and therefore you don't need to pay that premium price for it. If you don't mind spending the money, there's no reason NOT to use it (as far as I know). But, I think an overall recommendation for an older carb'd or EFI engine would be any TCW3 oil, depending on which brands you personally trust. Like the Quicksilver TCW3 oils, one of the other outboard engine manufacturer's name brand, or any other name in oil that you trust.
