Mercury 150 Salt water series cutting out.
Hello all,<br />I have a Merc 150 that is cutting out at 5100 rpm and over. I believe it to be a fuel problem. I have installed a new inline fuel filter and it seemed to help.It was cutting out very slightly in the 4500 rpm range. I then installed a attwood fuel water sepertor that came from walmart and this started after that. I have since ordered a racor filter in hopes that it may help. Im thinking that the attwood doesn't supply enough GPM , the package does't say how much it supplies but I figure I can't go wrong with the Racor either way. The cutting out is intermittent, sometimes worse than others. what else should I be looking for? The motor only has about 20 hrs on it and it's a 2004. Maybe tank pick up? I was told by the dealer that he thought it maybe the rev limiter but was advised by Walleyehed that this shoudn't be the case as the rev limiter on that motor was probably set at around 6200 rpm for that motor.thank you in advance .<br /> Matt
