  #1
Old April 1st, 2003, 11:09 AM
Mathew15 Mathew15 is offline
Default Flywheel Removal on a Yamaha 2hp - Need Help
Hello Everyone, Im trying to remove the flywheel on my Yamaha 2hp because I have no spark and this is where the charging system is. Well I need some help removing this piece, if anyone knows anything that might help let me know. thanks alot
  #2
Old April 1st, 2003, 01:07 PM
Squeakit Squeakit is offline
Default Re: Flywheel Removal on a Yamaha 2hp - Need Help
If your motor is a late model with solid state ignition, you may have a bad CDI unit (the black box, not the coil which has the plug wire coming from it) and this should be checked by replacing it with a known good unit. If you have to pull the flywheel, remove the flywheel nut and apply a good penetrating oil around the crankshaft, allow it to soak in for several hours, replace the nut so it is even with the end of the crank and give it a couple good whacks with a hammer - while prying up on the flywheel. If this doesn't do it you may have to use a puller. If it is an older motor with points, you can clean and adjust the points thru the slots in the flywheel which may take care of the problem. The newer motors with CDI dont have slots in the flywheel.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Flywheel Removal Fifty Johnson & Evinrude Outboards 4 August 15th, 2006 04:10 PM
removal of flywheel remant333 Mercury & Mariner Outboards 13 July 30th, 2003 06:49 PM
flywheel removal tonym302 Mercury & Mariner Outboards 6 November 16th, 2002 05:00 AM
Flywheel removal and Nut....... Jmorrell588 Johnson & Evinrude Outboards 9 August 30th, 2002 11:28 AM
Flywheel Removal karwash Johnson & Evinrude Outboards 10 October 13th, 2001 01:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
