Hello all,<br /><br />I have a Mercury 40hp ELPTO 967cc triple 2005 model. On a 4.2 stacer hull<br /><br />This model is fitted with an extra electronic control which I'd like to be able to overide at times.<br /><br />When you are trimming out, if above 2500rpm, it will not allow you to trim up past a certain point, it has a trim limiter which comes in above 2500rpm and pulls the motor back down to a preset maximum level of trim out.<br /><br />Occasionally I'd like to go above this, and was wondering if I can bypass it, or remove a fuse or something, guess you'd need to know the engine to do this. My mate has same engine 2003 model, his trims right out.<br /><br />My other question is that I feel that despite the motor having a foil, I'd like it to come up more at the stern when planing, would moving the motor down achieve this? (on its bolt position I mean) By going down the motor will still find its level, hence lifting boat higher? or am I wrong way round there??<br /><br />Any advice from you top blokes appreciated,<br /><br />Ron
