  #1
Old February 27th, 2003, 04:42 PM
fishingbear5 fishingbear5 is offline
Default 1987 90hp Yamaha-oil injection
I have a 1987 90 hp yamaha with oil injection. I have not used the boat in about three months and i put the muffs on today to run it for a while but the oil light came on yellow instead of green. I immediately shut it down. The oil resevoir is about 3/4 full. Does anyone have any ideas on why the light came on yellow. Thank you in advance. Jim
  #2
Old February 28th, 2003, 05:14 AM
butlp butlp is offline
Default Re: 1987 90hp Yamaha-oil injection
I don't have my manual with me, but I think your oil tank level switch is sticking and sending a false alarm. Try putting a piece of wire through the oil fill hole and work the float up and down to free it. If that does not fix it, drain the tank and remove, clean or replace the level switch.Remember to bleed the oil pump if you do drain the tank and mix your next tank of gas 50:1, making sure the oil level in the tank is dropping before you go back to straight gas.Did you store the motor tilted? Its always better to store your motor tilted down in the running position!
  #3
Old February 28th, 2003, 06:57 AM
Thank you for the information. I will try that and let you know if that fixed it. I did not store the engine in the running position but i certainly will in the future. Tight lines, Jim
  #4
Old March 1st, 2003, 03:14 PM
Thanks Lost Canadian. I went and got a manual for my yamaha and tested all the components. Everything checked out ok so i decided to remove and drain all the oil out of the resevoir. There i found the problem, the black ground wire from the sensor was not securely attached to ground. As soon as i pulled on the ground wire, the red light and buzzer came on. Thanks very much, Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 115 oil injection problem imported_tigger Yamaha & Suzuki Outboards 3 August 5th, 2006 10:41 PM
90hp yamaha oil injection flow test _dan1el_ Yamaha & Suzuki Outboards 1 January 30th, 2006 05:44 PM
1987 70 HP Yamaha, oil injection CT-Kurt Yamaha & Suzuki Outboards 3 September 5th, 2003 06:53 AM
1987 yamaha 115 oil injection system Tim Laurent Yamaha & Suzuki Outboards 7 September 7th, 2002 10:11 AM
1987 yamaha 90hp tilt motor wmikeg Yamaha & Suzuki Outboards 2 August 28th, 2002 07:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
