jcallicoatte
- Mar 12, 2006
- 4
I have a 2003 Mercury 40 hp ELPTO, 3 cylinder,oil injected. Recently the 2 cycle oil has been leaking out. It runs down the shaft and puddles outside of the motor on the ground. The motor was stored for the winter with a full tank of oil in the resevoir in a tilted position supported by the transom saver. No different than any other i have ever had. There are no leaks from the supply line to what i think is the pump itself. Can this be a siphoning issue? Additionally the motor will die under load past half throttle. Runs fine at idle both in neutral and gear. Feels like flooding out at full throttle. Will open up if you spray starting fluid while under way. Is this fuel pump issue altogether?
