  #1
Old February 11th, 2003, 04:33 AM
Simon Wootton Simon Wootton is offline
Default Yamaha 4 Floods then dies...
Used to be intermittent - motor stops after 2/3 minutes.Now this is more persistent from starting.Plug is fouled very quickly.Is the carb / fuel system the likely cause? If it is, how easy is it to clean inside the carb?Any help gratefully received!
  #2
Old February 11th, 2003, 05:14 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: Yamaha 4 Floods then dies...
All depends. If the motor is not firing right, then the weak cylinder/s would be wet from lack of fire, but more than likely you have a carb problem and they will have to be taken off and cleaned good and maybe just a good ol' rebuild on them to be on the safe side, because you could have a problem that cleaning won't take care of, but first determine that the engine is firing on all cylinders and get back to the forum, for there is always someone around that will be than glad to help if they can.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old February 12th, 2003, 06:58 AM
Thanks - the engine is a single cylinder that I used as an auxilliary, so it hasn't had lots of regular use. When it runs it seems sweet enough but it has this annoying habit of randomly going splutter , smoking and dying.Any ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 115 2st dies at 1100 or less rpm hiflyer Yamaha & Suzuki Outboards 5 June 8th, 2006 03:57 PM
1988 Yamaha 130 will not run at WOT and dies ??? fishon71 Yamaha & Suzuki Outboards 14 June 14th, 2005 04:54 AM
yamaha 150 dies at idle ddaigle Yamaha & Suzuki Outboards 3 April 28th, 2004 04:54 PM
Yamaha 3.0 I/O dies when put in gear. whiteboy71759 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 April 17th, 2003 07:41 PM
Yamaha Experts-2000 Yamaha 225 OX66 EFI-WOT Dies wi1p Yamaha & Suzuki Outboards 2 March 12th, 2002 02:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
