Yes, it should start.
try squirting some mix directly into the carb bodies, and try it. If itr sputters, the carbs need to be cleaned. I would suspect the kill switch/lanyard circuit tho. I'm not sure how they werk on that engine, only that they are present.
You might have to buy the manual for your engine (I would advise that anyway, as it will pay for itself over the course of ownership,garunteed).
Don't be overly concered with the numbers, on an engine that has sat unused for a year.
After you get it running, run it at least until warm, let it cool, and take readings again. A decarb treatment may free sticky rings too.
