  #1
Old January 19th, 2003, 10:33 PM
snapperman snapperman is offline
Default How do I bleed the precision Injection on my Yamaha?
I have one of these fab Yamaha 90hp. It's been out of service for a while, I've just got it going on premix and have found the precision injection is not working. I suspect it has air in it as it has been lying on its side for over three months. I was advised it had a bleed screw but where? cheers Snapperman
  #2
Old January 20th, 2003, 03:44 AM
clanton clanton is offline
Default Re: How do I bleed the precision Injection on my Yamaha?
If you are speaking of the oil injection, the bleed screw is on the oil pump, small philpps screw.
  #3
John from Madison CT John from Madison CT is offline
The Bleed screw is located on the oil injection pump itself.It is a small phillips headed screw with a tiny gasket.You should see it no problem.Just to be sure though, I always run at least a couple of tanks of premix thru the engine and then look to see if the oil reservoir tank has a noticable change in volume.Good Luck,john
  #4
Old January 20th, 2003, 03:46 AM
Clanton: Geez, what are the odds ? We posted an answer in the same minute.Time to buy a lottery ticket.John
  #5
Old January 20th, 2003, 02:42 PM
Thanks all, on my motor it appears to be a small screwdriver head not phillips and it's made of brass will try it laterMany thanksSnapperman
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 precision blend 1994 Beharro1 Non-Repair Outboard Discussions 2 August 2nd, 2005 12:20 PM
Yamaha 225 precision blend 1994 Beharro1 Non-Repair Outboard Discussions 0 August 1st, 2005 09:06 PM
By passing Yamaha 115 Precision Blend system maximus787 Yamaha & Suzuki Outboards 6 September 14th, 2003 11:23 AM
Yamaha Precision blend derowley0111 Yamaha & Suzuki Outboards 1 July 23rd, 2003 03:42 PM
Precision Blend for 90HP Yamaha snapperman Yamaha & Suzuki Outboards 5 December 18th, 2002 10:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
