problem rebuilding Mercury 60Hp 2 stroke 1998
cmyers_uk
I am rebuilding a 60Hp 3 cylinder Merc 1998 that had been in my garage for 5 years in bits. All has gone well except I have a bit I dont know where it should go. They are two relays on a bracket with one bolt on one end of the braket and a hook on the other end of the bracket. The relays each have a red wire joined together to a single connector and one relay has a blue/white wire and a blue wire the other has a green and a green/white wire. Where should these relays be connecting to / mounted. I know this is a hard one without photos!<br /><br />I think the relays may be for the power tilt and trim?<br /><br /><br />Thanks<br /><br />Chris
WillyBWright
Re: problem rebuilding Mercury 60Hp 2 stroke 1998
That's what they're for. Red is for Positive, Blue is for Up, Green is for Down (with or without white stripes).
cmyers_uk
Thanks, I have now matched the wires up correctly and typing with oily hands. I know I am being stupid but I cant see where the bracket should mount. I am thinking that the bolt mounts on the bottom of the starter motor but then the relays seem to foul the wiring. If anybody has a picture of a 60hp Merc on the starter motor side that should solve it. Sorry for being thick, I did take photos before taking apart but clearly at the time thought it would be bloody obvious where this went. Obviously I was wrong!
