  #1
Old January 6th, 2003, 08:24 PM
aussiefisho aussiefisho is offline
Default Frozen flywheel 25 yamaha or not?
I have a 1988 25hp Yamaha and have tried removing the flywheel to get at the coils as I have no spark to one cylinder. I have proven everything..spark plugs, coils leads, cdi box and wiring and it can only be a pulser coil playing up. I removed the pull start assembly and the fly wheel nut and have been trying to pull the flywheel with a puller but no luck.Is there something else to undo before pulling the flywheel or some other way to get at the coils? Does the top of the flywheel unscrew..it looks like its made up of 2 parts?
  #2
Old January 7th, 2003, 02:53 AM
rwise rwise is offline
Default Re: Frozen flywheel 25 yamaha or not?
aussiefishowith the puller in place and tight, take a hamer and hit the jam (center bolt in puller) with a sharp hit. do not try to hit it with everthing you got, you just want to shock it so the taper in the flywheel turn loose. If you have already done this thry a bit of heat on the flywheel, (maybe a hair dryer).Richard
  #3
Old January 7th, 2003, 04:19 AM
OBJ's Avatar
OBJ OBJ is offline
Hey aussiefisho....If the wheel don't pop when you smack the jam nut, keep as much tension on the puller as you can and put some Blaster or other kind of penetrating oil around the where the shaft comes through the flywheel. May take a while but I have had them pop off on there own after soaking for a while. Don't over do the smacking of the jam nut.Jim
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #4
Old January 7th, 2003, 04:21 AM
Capt Ken Capt Ken is offline
Ensign
I guess the European Yamaha is different than the ones here in the states. The 1988 25 hsp model here shows the two coils mounted on the port side of the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Frozen 115 yamaha lower unit!!!! rednspeck Yamaha & Suzuki Outboards 13 March 11th, 2005 09:22 PM
Pistons Frozen/ Flywheel won't turn Salder Force & Chrysler Outboards 4 August 12th, 2004 04:03 PM
Pistons Frozen/ Flywheel won't turn Salder Non-Repair Outboard Discussions 3 August 12th, 2004 05:43 AM
70 HP Yamaha Frozen Steering jmack325 Yamaha & Suzuki Outboards 5 June 29th, 2004 05:57 AM
1973 Evinrude 115hp frozen Flywheel Gazdzik Johnson & Evinrude Outboards 1 July 20th, 2002 10:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
