Hello heatstroke
First be sure this oil is in fact gear oil, leaking from the gear case. Make sure it is not exhaust residue dripping from thru hub exhaust. There could be other damage besides the prop. Use a dial indicator to determine if the prop shaft is bent. Check for fishing line, grass, etc wound around prop shaft. Look carefully at the exhaust housing (lower leg) and try to see if that is bent. Some times motors get backed over at the boat ramp. Folks forget to lift before launch. It my also have been involved in a highway incedent. Your prop can probably be repaired at a good prop shop. You may need to replace prop shaft seals. Lets hope thats all.
