  #1
Old December 26th, 2002, 04:40 AM
torr torr is offline
Default Yamaha Choke Problem
Hello,I have a 2001 F50TRLZ yamaha and the choke does not work. Part number of engine is 62Y L 422***. I need to know how to test the parts on the carburetors, these are two solenoid looking devices. Also I need to know how to test the wiring harness. The switch on the key has tested good with a continuity meter. Is there a control module somewhere on the motor for the choke?Or does anyone know where I could get manual for these newer motors?
  #2
Old December 26th, 2002, 12:43 PM
Trevor Trevor is offline
Default Re: Yamaha Choke Problem
If I remember correctly the yamaha 4s do not have manual choke but there is a trick to starting them you. first prime the primer bulb hard then pump the fast idel lever 3 times prime the primer bulb and start leave the fast idle leaver alone and let it idel and dead slow if it stalls prime it again pump 3 times then start it will go it you touch the fast idel leaver while it is warming they will usuly stall.!!Good luck
  #3
Old December 27th, 2002, 06:02 AM
Capt Ken Capt Ken is offline
Ensign
The two solenoids you mention is the prime start solenoids. They are located on #1 and #3 carbs. These are automatic systems and the choke switch on the dash does nothing. To start the system, you leave everything at idle and turn the key. If you advance the throttle any, you disengage the system. With the engine cold, you can disconnect the to wires going to each solenoid and connect a meter. When you turn the key, you should get voltage.
  #4
Old December 27th, 2002, 06:50 AM
Thank you Capt Ken. I will try this and see what happens.Tim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 200 hp choke, rpm, carburator abbe1 Yamaha & Suzuki Outboards 1 June 13th, 2005 04:27 PM
2.2hp Yamaha Choke and Idle problem diaolarmor Yamaha & Suzuki Outboards 1 May 17th, 2005 05:42 AM
1999 P150TLRW Yamaha motor choke problem randy650 Yamaha & Suzuki Outboards 6 August 5th, 2004 09:48 AM
'90 Yamaha 115 Choke? Bozo Yamaha & Suzuki Outboards 6 April 27th, 2004 08:18 PM
Yamaha 9.9 choke question gator79 Yamaha & Suzuki Outboards 0 July 14th, 2003 04:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
