65 Merc Problems
Scotty1
I Got myself a 65HP Mercury I need to find the serial numbers and model numbers, <br /><br />All the motor tell me is 650 4 Cylinder, 65 HP Mercury with thunderbolt ignition. What is thunderbolt ignition, <br /><br />I'm looking for all info available as i don't even know what year it is<br /><br />Thank you
Laddies
Banned
Re: 65 Merc Problems
Numbers should be on the front of the swivel bracket or stamped it to the top of the block above the sxhaust plate. Thunderbolt Ign. is CD ign, on the 4cyls. it was battery operated and the 650s 4cyl with CD were built from 1967 to 1971
hoss62773
I've got a similar 65 hp. my serial# is stamped between the two bolts that clamp your motor to your boat.
